converting 9 volts to 6 volts?
i know how to solder and built circuits if i have a schematic provided .so could anyone provide me with a small circuit schematic or is it just in need or putting a resistor in between the terminals?
8
answers
Answer it!
And a 9V battery has a very low maximum current draw, not suited to devices with motors in them.
Plus if you use a linear LDO regulator to drop from 9V to 6V, all the power dropped in the regulator is wasted energy.
And one alkaline 9V battery costs more than four alkaline AAA batteries. Same for NiMH.
The 78xx series of regulators requires a minimum of 3V above the output, so for a 7806 it requires 9V minimu, so a 9V battery will quickly drop below 9V.
So if I were you, I'd use four AA or AAA batteries to replace the CR123A
L
That is a good point- if space is really precious, don't waste 3V out of 9V in a regulator, just use smaller batteries. I'll bet there is more free space inside the tank, though.
If you want to put rechargeable batteries in there, you could pick and choose from some of the many flat and odd-shaped Lithium-Ion batteries, but you'll need to build a custom charger. Google is your friend...
I've got some of those Li-Ion batteries, but done nothing with 'em yet - any help?
L
i actually just modified a controller for an rc robot to use a wall outlet, because it would suck a 9v down to nothing relatively fast.
