could I use pvc cement on upvc pipes?
Dear sir,
I'm in title to use pvc cement to glue with it upvc pipes & fittings, pls advise if applicable & works which I had been using it before & it works . advise also ur recommended materails to use .
Burf7 years ago
If you are asking if PVC type N cement will bond uPVC pipe, yes it will. But it is not recommended for pressurized systems, (fluids or air).
If you are planning to use the pipe for something like compressed air lines, you will need the type P cement .
