does my circuit need any resistors? Is the capacitor needed ?
Yes, Nice fat 100uF where the power enters your board, with a 100nF ceramic across that, also 100nF on the output of your voltage regulator
drystreams (author)  steveastrouk3 days ago
Thank you! I understand you suggest I put one on the input of the board and on the output of the voltage regulator. What does "with a 100nF ceramic across that" mean? Not being sarcastic but I want to make sure I understand what you mean. Thank you.
Put a 100 nF cap in parallel with the 100uF capacitor
Like this? Sorry I'm new to this.
drystreams (author) 4 days ago
mistake on diagram. how it really is
The blue wire is what triggers the relay from NO to NC. The regulator is an NTE960. I have not had any issues (running for 3 days) with not enough power or regulated power. I will incorporate. Made a mistake on the diagram. Here is how it really is...
iceng4 days ago
By all means daystreams your ecoli incubator circuit aha is here
https://www.instructables.com/community/TE9RPH4JAV...
I do not understand the blue wire to the relay which needs a reactive diode across the coil.. Excluding the heater & relay, each component that uses power needs a filter cap 4.7uF tantalum or electrolytic and a 0.1uF disc or mylar as close as possible.. Especially both sides of the regulator..
rickharris4 days ago
More than likely.
Needs more polishing ICENG.
+1
This occurs when there is no corresponding image supplied daystreams.
