does voltage matter in a capacitor or is it only uf?
ive seen volt numbers on capacitors but people mostly just mention uf. but the uf is the same but the size of the cap looks different. does voltage matter?
Picture of does voltage matter in a capacitor or is it only uf?
The voltage rating for a capacitor is the maximum voltage you can apply without breaking the capacitor.
If you do not see why that number, the voltage rating,  is meaningful, consider something similar like the pressure rating for a tank that holds compressed air. Does it matter how big the tank is? Does it matter what the highest pressure the tank can withstand without breaking? The answer to both is yes. Both of these numbers are meaningful. Both matter.
+1
jeff-o7 years ago
Yes, voltage matters very much. If you expose a capacitor to a higher voltage than it's rated for, it'll probably blow its top. So, make sure that the voltage rating on the cap is greater than the voltage you're expecting it to handle. For example, that 6.3V cap would be perfect for 5V circuits or less.
Also be aware that some capacitors are polarized, and some are not. In the picture above, you can see a band of "-" signs indicating the negative pin of the capacitor. Again, make sure it's hooked up the right way or it may rupture or explode.
MatthewN20 jeff-o11 months ago
Jeff-o i know this is kind of old but i use a lot of 5v stuff. just to make sure im correct as long as my compacitor ratting is greater then 5v. im ok as long as i only use a 5v source?
Sir,I bought a capacitor with rating 63v but I had to use 16v so will 63v work perfectly in place of 16v???? Thank you too much! !
Yes, you can use a 63V capacitor in a 16V system.
MarkS4971 year ago
Replacing both power supply caps on 100 watt Crest pwr. amp. I orderd 10,000Uf 67wvdc . Received 10,000 Uf 63 wvdc......will they work?
DavidT3301 year ago
I am using a different voltage capacitor for a 555 timer circuit, the cap I am using has greater voltage than the spcified in the circuit, so could that cause misfuntionality?
etipton4 years ago
It only matters if you are trying to use a capacitor that is rated for X voltage and your system voltage is higher. Capacitance is capacitance
No as long as you are useing a higher voltage than the original and NOT a lower voltage.
Put a 6.3 volt capacitor into the mains and see it melt the plastic film around itself and turn black and smelly (don't do it).
