loading
double blink LED control?
there are three sets of LED I want to control, one function is dimmer, another is simple flashing LEDs, then I want two double blink LEDs( like a firetruck, blink blink pause blink blink pause) the simpler the better..i can find the first two circuits pretty easily , the third double flash is harder to find. is there a simple circuit that would do all three?
I have built that just follow this Instructable
https://www.instructables.com/id/Emergency-Flashers/
To add the different functions add a selector switch to the LEDs to the different stages of the circuit.
NMSquirrel (author)  Josehf Murchison3 years ago
That's a simple flash circuit, easy enough to find..what about double flash? blink,blink,rest
If you modify the circuit in step 8 like this you get a steady flashing LED and a flash flash rest LED.
NMSquirrel (author)  Josehf Murchison2 years ago
PCBoards have arrived, damn I knew I would order wrong.. the 555 came SMD, I think all the capacitors are wrong ones.. but two of the four I think can still be used, the others are way too big.( which is why I asked about kit) wanna order for me and ill paypal you? (now have 10 boards 2x2)
(I only ordered for one, cause I knew I would screw up the order)
Tell you what I will swap you.
I have to go out but I will PM you with my address when I get back.
Joe
NMSquirrel (author)  NMSquirrel2 years ago
and he did send me a copy of the layout for a pcb, I didn't think of it then, but I asked him to resend me a copy of that so I can share it with you.
here it is
is it critical to use the fr151 diodes??(cant order less than 500) is there a replacement?
If you stay under 1 amp you can use a 1N4001 to 1N4007.
Joe
is there a way to get this in kit form? (pcb and parts)
It is my design so I doubt anyone makes a kit, I use generic proto boards or I make my own PCB however, Schmartboards and others do make custom boards.
http://www.schmartboard.com/index.asp?page=products_raspberry_pi#
Mouser in Texas is where I buy my ICs and transistors, their prices are good some times as much as 1/10th as much as Radio Shack and the parts arrive in Canada within a week.
http://ca.mouser.com/Electronic-Components/
You can also get the datasheets on what you want to buy from Mouser from there web page.
Radio Shack and a couple electronics shops is where I get my other parts and I salvage.
I buy more than I need so when I mess up it is no biggy I have spares.
Rule of 5
1 for show
1 to blow
1 for defective
1 for testing
1 for finish
LM7805 10 for $5.52 at Mouser the price of 1 at Radio Shack.
SN74LS74A 10 for $19.60 at Mouser.
SN74LS08N 10 for $6.48 at Mouser.
And if you are just using small LEDs.
1N4001 10 for $1.34 at Mouser 1/5 the price of Radio Shack.
Joe
make your own boards..no thanks, I tried to get into that when I was young, if need be I will use a breadboard, but I did find this guy:
http://www.hobbypcb.com/
he said he could do a 10 count 2x2 for 50-60 and he would convert the schematic, still waiting to hear back from him.
and all we have here is radio shack but they seriously lack a variety of components, this is oilfield country, serious lack of nerds..
(salvaging was how I first got interested in electronics,)
The Source (Radio Shack Here in Canada) is pitiful here to also. I live in a small town and to get parts from a retailer I travel to Toronto or Guelph. About $120 travel costs so I only buy from a retailer when I travel there for some other reason.
I buy on line and it cost me less for shipping then the travel costs to go to a retailer. Companies like Mouser on orders over $25 ship for free and to be safe when I buy on line I buy with a prepaid credit card or a gift card, that way I can limit the damage if someone gets the card number.
I also get free components by emailing manufactures and asking for a free sample of what I want, that is how I got the VFD in this Instructable.
https://www.instructables.com/id/Arduino-and-the-Noritake-24x6-VFD-Module-Vacuum-Fl/
I can make that circuit board for less than $10 assembled PCB and all.
Joe
Go to the last circuit and video it flashes Left Left Right Right.
this is useful, thank you
iceng3 years ago
Here are two flashers available as beginner kits one for 5$ for the 555IC version
http://www.goldmine-elec-products.com/prodinfo.asp...
And the smd transistor version flasher for $7
NMSquirrel (author)  iceng3 years ago
that one flasher looks like what I have the schematics for, perfect, it has board and components in one place! will have to look around that site for a double flash controller and a LED dimmer.
They are both dual LED alternating flashers
MDheliMech3 years ago
Being into model railroads I have spent a great deal of time messing with LED control. I started out using 555 timer circuits. I got great results, but at the cost of having several different circuits. Using 555 timer circuits I could get any result I wanted including your deired blink blink pause blink blink pause. This video uses four 555 timer circuits. One circuit alternates the yellow headlights. A second 555 switches between two more 555s attached to the red LEDs which each blinked when triggered. if one of the two red LEDs were removed you would have blink blink pause
.https://www.youtube.com/watch?v=YJry3ApEKRE
Then I did the best thing ever. I tried Arduino. This video is just one Arduino.
https://www.youtube.com/watch?v=fY2bwoZJ4EA
The separate issue is remote control. have you chosen a method of remote control yet?
NMSquirrel (author)  MDheliMech3 years ago
this remote:
http://www.ebay.com/itm/12V-12Channel-Relay-RF-Switch-1000m-Remote-Control-Transmitter-Receiver-315MHz-/261238988236?pt=Home_Automation_Controls_Touchscreens&hash=item3cd30e9dcc
and I am going with pcb circuits on this one, BUT I want to play with arduino, so my next build will have one. I have this one almost complete as far as the thought process and research goes, (still have to buy the stuff)
Have fun, I would love to see it complete. I have always wanted to try something like lighting up a scale model.
long way till done, still waiting/spending on pieces parts and paints..
I have build log at http://scifimodelaction.com/sfmaforum/index.php
still in the beginning stages.
NMSquirrel (author) 3 years ago
is there a LED dimmer circuit that I can hook to my remote? controlling through a potentiometer would require putting a hole in my ship for a knob..
just explored PICaxe.com, think I found something I could use, they have a programmable reindeer with a remote! for like $12
https://www.techsupplies.co.uk/epages/Store.sf/secd0d03f66af/?ObjectPath=/Shops/Store.TechSupplies/Products/AXE108S
NMSquirrel (author)  NMSquirrel3 years ago
nope, found video of reindeer, wont work
on that reindeer: I cant find where it says how many outputs it can run..
I think you'd be better spending 20 bucks on the entry level programming kit, and making your own up.
http://www.techsupplies.co.uk/epages/Store.sf/en_G...
All you really need is
and the programming lead.
and the programming software
Bear in mind you can buy in the USA too.
http://www.picaxe.com/distributors/
NMSquirrel (author)  steveastrouk3 years ago
but,but, then there is an add-on USB wireless adapter, so I don't have to add a port to my ship, (but once I program it I wont need to reprogram it again,?)but, I would like a remote control, but it doesn't need to program, it just needs dim interiors, turn on/off spotlights, turn on/off xmas lights, but..the choice is getting down to this or arduino, I think this is looking cheaper..(did find a remote kit on e-bay for cheap)
Mmmm? You need a USB to serial cable - Not expensive. Picaxe can supply. The rest is free apart from the hardware.
Why do I feel there is more here then has been said?
What exactly do you want to do?
The picaxe forum completed projects will show you how to dim LEDS.
You CAN use a sony code IR transmitter to communicate with a picaaxe chip, built in software - Or even use another as the transmitter.
NMSquirrel (author)  rickharris3 years ago
building the nx-01, trying to get main nav beacon to double flash, the other beacons to just flash, dimming for the interior lights, then separate on/off control for spot lights, and xmas lights, trying to find the easiest way to do this, remote is for I wont have any connectors showing through the hull.(yes, i can run it through the base as with power,but i think it would be cooler with a remote.)
and i have adhd and tend to overthink things(and end up confusing myself), this case being one of them.
this is the remote I have been thinking about it would control on/off for spot lights, xmas lights and main power, it would control dimming for interior lights and binary clock led's.
Needs a little chip like the PICaxe
The simple circuit would be using a micro contorller like an arduino. Just plug the LEDs in with a resistor and the circuit is done. Then all you have to do is program in your modes.
