3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
eBook creation software question?
What is the best (free) software for converting word documents with images to an ebook format compatible with the Kindle?
Aug 29, 2011. 7:55 AMrickharris says:
I have saved my documents as a PDF and then sent to my kindle. Works fine.
Stanza, Caliber Kindle them selves!!
Send it to your freekindle address and they will convert the Doc file for you (free)
Aug 29, 2011. 12:35 PMrickharris says:
From amazons kindle page
"Personal Document Settings
You can e-mail personal documents to your Kindle's e-mail address. Amazon will then transfer the file(s) wirelessly in a Kindle-compatible format to the related device for a fee. To avoid a fee, or if you're not in wireless range, you can e-mail your document to [name]@free.kindle.com for free delivery via wi-fi or download the files via USB."
Sep 8, 2011. 3:28 AMrickharris says:
It appears to say "IN A KINDLE COMPATIBLE FORMAT" What do you get - To be honest I haven't tried to do this (yet)
This may be a help
Sep 8, 2011. 3:57 AMrickharris says:
Sep 7, 2011. 9:50 PMLithium Rain says:
So, have you found a solution which works for you?
Sep 8, 2011. 9:23 AMLithium Rain says:
I'm happy to help, but without knowing what the issue is with the suggestions already put forth, I'm not sure how. Glad it's not as urgent though. :)
Aug 30, 2011. 11:17 AMLysias says:
I know this isn't ideal, but I have used a free application called pdf2epub (it converts to mobi too). It would mean you would first convert to pdf though, but it does a great job.
Aug 29, 2011. 5:44 AMrimar2000 says:
I don't use a Kindle, use my cheap generic tablet with Android or my cheap generic GPS with Windows CE.
In both cases I read almost exclusively TXT. I think that all word processors can convert documents to TXT. You lose images, that can be a problem in some cases. For that cases I use a PDF reader. OpenOffice can export documents as PDF.
Aug 30, 2011. 5:48 AMrimar2000 says:
A spanish saying says "en el pecado está la penitencia". Google translates it bad, I think.
It means that some sins have it them own penitence. Your sin was to buy a Kindle. Buy a cheap generic tablet or a cheap generic GPS or even a cheap generic telephone, and you will fix the problem. My daughter has the same trouble, but as the reader was gave it for her husband, she can't discard it... (!)
Aug 29, 2011. 3:46 AMsteveastrouk says:
Tried Calibre ? Steve
Aug 29, 2011. 5:38 AMsteveastrouk says:
Did you read the tutorial ?
Steve
Aug 29, 2011. 6:01 AMsteveastrouk says:
The tutorial explains how to lay the job out and create an ebook, rather than turning a .Doc into an ebook, if you see what I mean.
Steve
Aug 29, 2011. 4:48 AMundescriptive says:
I use MobiPocket Creator - it works with kindle (and kindle apps) but you have to copy the files directly to the memory of the kindle using explorer
Aug 29, 2011. 6:06 AMundescriptive says:
yes it does :)
I'm not entirely sure what versions it will cope with - so save out as 97/2000 doc and it should be OK
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
