flow meter?
how to construct a flow meter to measure the flow of water(or any fluid) at home?
what materials and construction steps are required??
seandogue3 years ago
It kinda depends on how accurate you want it to be and what resources you have to make one
a simple flowmeter could be built using a light duty dc motor (as a "generator", ie, v-sensor) , a handmade paddle wheel, and a channel within which the water would flow. Alternatively, a paddlewheel, a rotary disk with alternating bands of light and dark and a photo interrupter circuit could be used for the purpose.
If you happen to have a homemade Laser Doppler Anemometer, That could be used as well, presuming the fluid has particulates in it. ;)
What kind of volumetric flow rate are you interested in ? Litres/sec/min/hour ?
Just buy one.
http://www.adafruit.com/categories/106
Many of these meters use an impeller with a magnet inside that induces a current in an inductor as the impeller spins. With the right circuit it can convert that into pulses a micro controller can count and do the math to estimate the flow rate.
Which is a viable solution for those of us with money and access to international shipping companies. Many contributors don't have the resources we take foregranted.
+1
