frequency tesla coil function a? IRF9130? circuit cold electricity?
I will be putting together several joule thief's and after i get them to sustain each other i intend to use the circuit with the IRF9130 to power a tesla coil. i also intend to use the JT to power an E-bike that is fast enough to travel on the highway's.
any help is greatly appreciated!
also, what is a Batt-cap? and where can i find them? the batt-cap in question is stated to absorb all of the batteries power and recharge it after it is fully depleted. source from:http://free-energy-info.co.uk/Chapt5.html
33
answers
Answer it!
A regular spark gap Tesla coil runs between 100-500 thousand kHz, this is a rough average, you can't really say any specific frequency.
This circuit is not a Tesla coil, but it can be used to power one.
An IRF9130 has a lower voltage than a IRFP460 this means the IRF9130 may fail in the kind of circuit you're building.
IRFP460 not IRF460 however the two do seem quite similar.
I have done experiments using Tesla coils and resonant coils the max result is about half of the output power. I am still going to continue sometime with different forms of resonant circuitry.
Yes I have played with TC receivers, you will have to play with the topload of the receiver to fine tune it.
I chose a 1k variable resistor (using it as a none V) and a pvc cut off about 2 - 2 1/2'' also I tried a 1/4'' to no avail. the power is not being amplified or passing through the circuit as is should. I fiddled with a wire and found that the power is passing through the 2n3409 transistor. nothing i've done will make it do as it does in the youtube vid how to make a joule thief. http://www.youtube.com/watch?v=gTAqGKt64WM i'm at a loss.
I really don't know much about joule thief's, but you might like to try the circuit on this site, I've been meaning to try it sometime. This circuit would be interesting around a Tesla coil especially if the antenna is a resonant coil or possibly fractal.
The other ideas I am yet to test involve these, I find them much more interesting than Tesla coils because the circuit can be manipulated more to do other things like receive power.
Q: would a simple reed switch be suitable to cause an electric pulse? or perhaps something else that via a AA would provide an electric arc at high frequency.
Please keep in mind, though i would like to use 12v car battery, i am only able to use 1.5v batteries as power source.
A reed switch looks a lot like a relay if so it would be suitable to create an electric pulse (I have done it before whilst connected to a transformer), with the pulsing you should be able to connect it to an ignition coil and have you're power source. See this.
i am unfortunate to be unable to apply my knowledge gained form researching, but in the very least i can depart what i've read to those who have the resources i do not.
http://freenergynow.blogspot.com/2011/07/combined-generator-and-motor-need-help.html
I suppose I should post it to Instructables. At least then, I might actually gain the answers I desire.
By the way, how does a person navigate this site when it seems to only give random suggestions. The search bar as I have tried, goes straight to google and is far less useful then using google to search this site.............I'm perplexed......
- The metal case is the Drain ( 3d terminal ) of the IRF9130.
- The Gate ( pin 2 ) goes to the 470 Resistor.
- The Source goes to +12V
- The 555 is oscillating about 100 Hz
- Tesla coils operate at RF you want current to flow over your skin not through it.
- Cold electricity ?
- Joule thief's suck batteries dry and cannot power an E-bike !
- There is no such, good luck ;-)
Each collector must have a 1 ohm resistor in series as does each base require a resistor.
You have a strong single minded obsessive need
Mine is collecting best answer author gratuities.
While at present your too centric to get it.
I do respect your multifaceted pursuit of an impossible goal
That drive can serve you well.
A
At the moment due to lacking of resources, it is indeed nearly improbable that I will achieve my goal/s of harnessing aether. but that's no reason to give up.
I desire to collect as much info as possible to obtain desired results, I have been researching for a few months shy of a year. At first I was attempting to learn the math to build a simple motor/generator, alas found my searches to be Extremely difficult. I need Exact math for intended designs, but only found answers to complicated to fully understand; simple is what i require.
this is the general idea of what I originally was trying to learn: http://freenergynow.blogspot.com/2011/07/combined-generator-and-motor-need-help.html
I want to be able to use Longitudinal waves with the Coil rather then simple RF.
Just look up Cold Electricity in reference to the greats of Electrical Engineering.
A Joule Thief by its self, no, but when configured properly will aid in powering 1.
Ether is Energy from the Natural Environment and Cold Electricity is a side effect.
Try Logic, Don't you think the material you squeeze out here would be in production, available to all consumers, if there was Real engineering behind the claims ? ?
A
if you have any info on cold electricity and how to obtain it please let me know, thanks.
