has anyone done anything with pressed powder candy before?
I've seen instructions all over the internet (both here and other places) for nearly every type of candy except pressed powder candy. I've been experimenting myself with it, but the process is rather tedious, and I'd really like the help of someone who's done it before. I'm basically trying to come up with a good way to make caffeinated candy, and I think that pressed powder is the best way to go. so far, I'm making tablets using sorbitol, sucralose, caffeine and kool-aid, and I'm pressing the tablets using a cheap press (actually intended for "herbs") in a vice. however, my tablets are still flaky, and they dissolve almost immediately in the mouth; I think I need more pressure, and I think I'll only get that through a real machine. however, nobody seems to be making a cheap human-powered press that I'm aware of. If anybody's done this before, or attempted it, I'm just trying to get some advice on the best ways to go about this experiment.
Feb 23, 2012. 1:11 PMVyger says:
If you need to use more pressure, and that is entirely likely, there are some ways of adapting equipment that might work. A common hydraulic bottle jack can produce large amounts of compression. They have been used for all kinds of things like pressing in and out bearings. There are some places that make press set up's that you could adapt and you can also go the do it yourself route. One guy is using a set up to compress the powders for rocket engines. This might give you some ideas.
http://blog.skylighter.com/fireworks/2008/12/how-to-make-a-hydraulic-rocket-press.html
And they are apparently also used in jewelery making. Pressing out blanks of metal and such.
http://www.potterusa.com/index.php?option=com_virtuemart&Itemid=58
So, you can get or make a press that can do the job. The bigger problem might be getting the die. You might have to make that also.
Feb 23, 2012. 1:23 PMlemonie says:
Be aware that other powders are pressed into tablets; if you have yourself a pilling-machine you may attract suspicions of manufacturing illegal-pills.
L
Feb 25, 2012. 2:17 AMlemonie says:
Addictions are not good, I think this is mostly psychological and you could quit if you wanted to?
L
Feb 25, 2012. 3:16 PMlemonie says:
Then do it and feel normal, why keep pumping your self with a mediocre-drug?
L
Feb 26, 2012. 10:49 AMlemonie says:
I don't want a fight either, I like to challenge people because you usually get something interesting. Otherwise they shut-up and delete the topic...
L
Feb 27, 2012. 12:38 PMlemonie says:
I think you've got a good subject there (maybe that's what I should write my final paper on in my writing class).
I don't challenge people to just to see what they say; see here I've got what you're thinking about maybe writing from "you may attract suspicions" - isn't life interesting eh?
L
Feb 24, 2012. 3:12 AMfrollard says:
caffeine and candy (particularly if sold) are controlled substances in most countries...FDA or 'local food inspection agency of choice' would definitely be a consideration.
'raw' caffeine is quite dangerous so its important to have that measured safely/accurately.
Don't get me wrong, I love what you're doing - just be careful!
Feb 23, 2012. 1:46 PMBurf says:
Its quite possible you don't need greater but you need to adjust your recipe a little for better results. First, experiment a little by adding some corn starch to act as binder and see how that works.
Feb 23, 2012. 2:03 PMVyger says:
also brown sugar which compresses and turns rock hard.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
