loading
help, i want to make a glowing logo with mobile phone lcd backlight ?
I have an lcd from my old LG GW 300 and it was blank white, last month I was read tutorial how to add glowing logo like apple mac and it use lcd backlight from portable game console but i forgot to bookmark the address link and now i confuse what to do ?
I just want to light up the backlight of my phone lcd, it has very tiny flexy cable and I dont know which one to use ?
Picture of help, i want to make a glowing logo with mobile phone lcd backlight ?
Not all phone LCDs, (Liquid Crystal Displays) have the back light in the LCD.
If you have the circuit board look for LEDs, (Light Emitting Diodes) under where the LCD was.
They may be SMD, (Surface Mount Device) or they may be hole through that looks like a white rectangle and the LED emits out the side to the LCD.
Most LCD backlights are the last two contact points so if you know which pin is pin 1 and there are 12 pins it would be pin 11 and 12.
You can try a multymeter set for continuity and checking to see if it lights up when you connect to the right pins, this doesn't always work.
On the datasheets they are marked K A see my Instructable Salvaging Liquid Crystal Displays (LCDs)
https://www.instructables.com/id/Salvaging-Liquid-Crystal-Displays-LCDs/
rannur (author)  Josehf Murchison3 years ago
the circuit board is already gone I found this LCD when I clean up my roomi don't know which is the pin 1 and this lcd has 27 pins
can you help me find the right pins, cause i dont have a multimeter
oh, i found the link that i've ever read before
https://www.instructables.com/id/Glowing-paw-sound-...
