help upgrading an old RC truck?
im not looking to repair the batteries though, im looking to upgrade the truck with a little bit of some newer technologies.
heres where i ask for help:
i dont want to overpower the control board in the car, since it may have adverse effects on how it performs, so i just want to up the power to the motor. i have some D2583 and B1658 transistors, i found a datasheet for the D2583's that says they are high power NPN transistors, but no such luck with the B1658's.
using the D2583's (i have 6 of them), i want to create a circuit that runs from the main board, and acts as a second H-Bridge (or some sort of control circuit) that controls more power, so i can safely run more voltage to the drive motor without overpowering the main circuit board.
does anybody know how i can do this?
i have attached a picture of the area on the circuit board where the original H-bridge is.
18
answers
Answer it!
now all you have to do is just disconnect the wires from the motor now when the left button is pressed one of the two wires goes at high potential and conversely when right is pressed the other goes at high potential (you can figure it out using voltmeter)
NOW connect the wire that goes high when left button is pressed to the left labeled in the schematics and similarly right to right wire (IF U WANT I CAN MAIL U THE SCHEMATICS)
this will almost isolate the motor and its current from the other circuitry
and here transistor is operating as a switch (in case if u don't know)
connect "MOTOR NEGATIVE WIRE" to left labeld in the schematics
connect "MOTOR positive WIRE" to right labeld in the schematics
connect " BATTERY NEGATIVE TERMININAL" to ground in the schematics
connect "a NEW BATTERY" to the source in the schematics
http://www.crusher.so
robots arent as fun as controlling it yourself :3
i just wanted to play it safe because im moving from 6v to either 9.6v or 19.2v, im not sure if the standard transistors could handle all that, or the control chip.
Worst case if you can't add a heatsink is to add a fan :D
adding a fan or heatsink cant really be done with the transistors on the board, the board is mounted upside down and its mounted using the battery contacts.
thats why i figured another transistor set would be the best idea, i could use a regulator for the board and straight power for the drive motor.
