help with labeling switches on web page, please?
#include <SPI.h>
#include <Ethernet.h>
// MAC address just has to be unique. This should work
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// The IP address will be dependent on your local network:
byte ip[] = { 192, 168, 0, 15 };
EthernetServer server(80);
int numPins = 8;
int pins[] = {2, 3, 4, 5, 6, 7, 8, 9};
int pinState[] = {1, 1, 1, 1, 1, 1, 1, 1};
char line1[100];
void setup()
for (int i = 1; i < numPins; i++)
pinMode(pins[i], OUTPUT);
Serial.begin(9600);
Ethernet.begin(mac, ip);
server.begin();
void loop()
EthernetClient client = server.available();
if (client)
while (client.connected())
readHeader(client);
if (! pageNameIs("/"))
client.stop();
return;
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
// send the body
client.println("<html><body>");
client.println("<h1>LIVING ROOM</h1>"); //this is what it shows in the h
client.println("<form method='GET'>");
setValuesFromParams();
setPinStates();
for (int i = 0; i < numPins; i++)
writeHTMLforPin(client, i);
client.println("<input type='submit' value='Update'/>");
client.println("</form>");
client.println("</body></html>");
client.stop();
void writeHTMLforPin(EthernetClient client, int i)
client.print("<p>Switch "); //shows switch on website
client.print(pins[i]);
client.print("<select name='");
client.print(i);
client.println("'>");
client.print("<option value='0'");
if (pinState[i] == 0)
client.print(" selected");
client.println(">On</option>");
client.print("<option value='1'");
if (pinState[i] == 1)
client.println(">Off</option>");
client.println("</select></p>");
void setPinStates()
digitalWrite(pins[i], pinState[i]);
void setValuesFromParams()
pinState[i] = valueOfParam(i + '0');
void readHeader(EthernetClient client)
// read first line of header
char ch;
int i = 0;
while (ch != '\n')
if (client.available())
ch = client.read();
line1[i] = ch;
i ++;
line1[i] = '\0';
Serial.println(line1);
boolean pageNameIs(char* name)
// page name starts at char pos 4
// ends with space
int i = 4;
char ch = line1[i];
while (ch != ' ' && ch != '\n' && ch != '?')
if (name[i-4] != line1[i])
return false;
i++;
ch = line1[i];
return true;
int valueOfParam(char param)
for (int i = 0; i < strlen(line1); i++)
if (line1[i] == param && line1[i+1] == '=')
return (line1[i+2] - '0');
return 0;
Visit Our Store »
Go Pro Today »
Steve
Developers dont comment like this because its a waste of time.
You really should spend some time learning what an array is, as well as a function, and parameter otherwise you will just be spinning your wheels.
#include //library required to talk spi (This is how the arduino talks to the ethernet shield)
#include //library to talk to the ethernet shield
//Start an ethernet server on port 80
//variable to denote the number of pins to loop through
int numPins = 8;
//array containing the pin numbers you want to use
//array containing the states (on or off) for the pins you want to use
//a 100 character buffer we'll be using
char line1[100];
//this is run once when the sketch starts
void setup()
//loop through your pins and set them all to OUTPUT mode
//start serial with 9600 baud rate
Serial.begin(9600);
//initialize the ethernet device
//start the web server
server.begin();
//this is run constantly as long as the arduino is on
void loop()
//create and ethernetclient named "client" variable and put any data that was sent to the server in it
//if any data has been sent to the server
if (client)
//while someone is connected to your server
//run the readHeader function with the data thats in client
readHeader(client);
//run pageNameIS and depending on what it returns close the connection
//so if the page the user is requesting is NOT / then close the connection
client.stop();
return;
//print some html
client.println();
// send the body
client.println("");
client.println("LIVING ROOM"); //this is what it shows in the h
client.println("");
//run the setValuesFromParams function
//run the setPinStates function
setPinStates();
//loops through all your pins and writes the html to display them
//print the last bit of html
client.println("");
client.println("");
client.println("");
client.stop();
//writes html for selecting pin, and whether or not the pin is currently selected
client.print("
"); //close the select objectclient.print(pins[i]); //print the pin name
client.print(" client.println("'>"); //close the select tag
client.print(" if (pinState[i] == 0) //make the object selected by default or not depending on if this pin is currently on or off
client.println(">On");//close the option object
client.print(" if (pinState[i] == 1)//make the object selected by default or not depending on if this pin is currently on or off
client.println(">Off");//close the option object
client.println("
void setPinStates()
{//set the all pins according to what is in the pinstate array
//turns all of your pins on or off depending on the parameters given in line1 (from the web user)
// read first line of header and put it into line1
char ch;
int i = 0;
while (ch != '\n')
ch = client.read();
line1[i] = ch;
i ++;
line1[i] = '\0';
//this function returns true if the page requested is the same as the parameter passed to it
//gets the 4th character from line1
int i = 4;
char ch = line1[i];
//while the 4th character from line1 is not ' ' '\n' and '?'
//checks that the data after the 4th character is the same as the parameter name
return false;
i++;
ch = line1[i];
return true;
//parses line1 and returns 1 or 0 depending on which pin you are looking for "depending on the char param"
return 0;
here is a basic explanation of arrays
so you understand what variable types are right?
int x; makes a variable of type integer (it can be whole numbers)
string junk; makes a variable of type string.
an array is basically a bunch of things stuck together (I say things because it can be more than just variables) but lets start with variables
int test[] = {1,7,5};
This makes an array of 3 integers, arrays start at position 0 and go up, so the 0 position for this array is 1, the 2nd position is 5 and 1st position is 7
you can access them like this test[0] (this is equal to 1)
test[2] (this is equal to 5)
This code loops through arrays using a for loop (this is something else you will want to learn)
I love teaching, but I also love teaching people to teach themselves... At this point you are going to have to learn a number of basics before you can solve this problem for yourself.
The biggest hint I can give (without coding it for you) is to make an array of strings, fill it with the names of the pins, and access it just like the code above does to print out the pin number.
And where libraries are used, they should drip with comment, or you can end up spending so long working out why the code does what it does when it goes wrong, you end up having to rewrite it.
everything had self explanatory function names/variables
correct me if Im wrong
Steve
Steve
Focus on
client.print("
Once you understand what this is doing. (the key things you should understand are function/parameter/array)
I would use a string array to print different things, or you could use a switch case.
You will need to do a bit of googling to learn what these things are first though :)
Ill give you a quick crash course, but I do not want to spoon feed, so take this and run with it on google
This line tells the compiler the code in between the brackets after it is a function named writeHTMLforPin
The function takes 2 parameters, client (which is a variable of type "EthernetClient" and i, which is a variable of type integer)
client.print("Switch "); This just prints "Switch "
client.print(pins[i]); This looks up a variable in the array pins, the position of the variable in the array it looks up, is based on what number is inside i
You should learn what an array is, Play with making your own functions, with some parameters.
My solution would be to make an array of strings, and do the same thing the code above is doing, but instead of printing out the variable in pins[i] print out the variable in yourstringarray[i]
Im a big fan of diving right into code without fully understanding how it works, but unfortunately... unless you have an insane level of drive, you will get discouraged quickly. You need at least a base level understanding of programming before tackling this
