how Accelerometer work in Electrical car to measure acceleration ?
i am working on electrical car sensor system . i have many sensors in car for different purpose. one of it is accelerometer.
My task is to measure the acceleration of car using accelerometer or gyroscope by Microcontroller .
Please give me some brief idea about it .
iceng4 months ago
A good accelerometer will indicate 1g when vertically aligned with gravity and NO actual Movement..
Most accelerators are two or three axis like this
https://www.jameco.com/z/SEN0032-DFRobot-Triple-Ax...
for under $11 from Jameco made to interface to any uP..
rickharris4 months ago
You have a few choices. An accelerometer is essentially a damped mass on a spring. You measure how far the spring expands which is proportional to acceleration.
Usually you have a small mass with some way to convert movement to electricity, a coil, a hall effect semiconductor, a piezo device can all be used. They give an electrical output proportional to the acceleration of the mass inside the device.
Buy a suitable device is my advice, 1 it will be reliable, 2 it will be calibrated, 3 you start off with a known quality to work with.
https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=se...
Amazon Uk carry several units at stupidly low prices. I am fairly sure they do so where you are or a similiar supplier will. then all you need to do is follow the advice of the unit data sheet.
