how can I remove a heatsink backplate which is stuck/glued to ?my motherboard?
Hi,I'm from Indonesia.I've just bought a new mainboard for my personal computer and  I want to install my old heatsink fan processor from my old mainboard. The problem is that I cannot remove the backplate which is stuck/glued with adhesive tape from my old mainboard. Has anybody got ideas to solve my problem,please?
Thanks
Prasetyo
if you stuck with using the old one heat will break down the adhesive just use a blow dryer and heat it up and pry it off
lemonie7 years ago
If you have a new board & processor you should have a new cooler (or have bought one). Why (after replacing the mainboard & processor) do you want to fit an old cooler? They sound incompatible, and decent coolers aren't that expensive.
L
I agree.  I assumed that the old processor was being used again.  If not them most processors come with a new fan and sink.  In my experience.
You can by retail packs with both, and when I have I've found the (AMD) coolers plenty good enough. But you can buy without also.
L
Re-design7 years ago
can you dissolve the adhesive with paint thinner or alcohol?
