loading
how can i build a trickle charger?
I want to build a solar powered battery charger so i need to know how to build a trickle charger i can hook the solar panel up to
Dr.Bill7 years ago
not really interested. huh.
Dr.Bill7 years ago
I have a very simple tricle charger that works off a power supply. uses a relay and a diode and a resistor And works very well without the overheating problem. cannot over charge the batt., And has a power tap for powering a shortwave radio. Interested? Private Message Me.
110100101108 years ago
diode to as high current as you can (atleast 5 A)
resistor : R ohm = (volts of panel - volts of battery - 0.7) / amps of diode
for example 12 V battery / 16 V panel / 5 A diode
R = (16 - 12 - 0.7) / 5 = 3.3 / 5 = about 0.6 ohm
a 24 V 40 W or 12 V 20 W lightbulb is appropriate resistor in the example
now just connect all in series with the diode pointing from the solar panel to the battery
Brakermaker (author)  110100101108 years ago
I'm sorry, I don't know much about this...could you be a little more descriptive????
OR, if you are feeling more technical, get a pic chip or other transistor made for trickle charging (less than $5) and use the above procedure for plotting the rest of your design. This will allow the battery to charge at one rate, and trickle at a significantly reduced rate. This can also manage temperature, etc.
