how can i cleen up a vary durty floor rug ?
i got a used car with a vary dirty enterer need to be cleened
Mar 31, 2010. 12:33 PMRe-design says:
Did you mean to type.
"How can I clean up a very dirty floor rug?  I've got a used car with a very dirty interior that needs to be cleaned"
Take it and have it professionally cleaned.  If it's really that dirty then home cleaning won't do a very good job.
Apr 16, 2010. 9:27 AMcheezies says:
well...there's 4 ways 2 go about it...
1. pretend like its not there
2. call a cleaning service
3. buy a new car (that's more  of a piece than mine is)
4. cover it up
Mar 31, 2010. 11:30 AMlemonie says:
Feelthy?
What sort of dirt are we talking about (as in loose/wet/dry/sticky/ingrained/stinky/oozy etc)?
L
Apr 12, 2010. 10:44 AMlemonie says:
Did you get it clean then, or is it still in need?
L
Apr 3, 2010. 11:06 PMl8nite says:
if you have a shop vac or air compressor just go to town with laundry detergent, plenty of water and a scrub brush. Be sure to vac out as much water as possible, then use an airgun to blow out the remainder
Mar 31, 2010. 4:49 PMacidbass says:
 vacum it then steam clean it
Mar 31, 2010. 11:53 AMBurf says:
Take it out of the car and spread it on the driveway. Vacuum thoroughly and then rent a carpet cleaner/shampooer at the local supermarket and clean according to the machines instructions.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
