how can i make copper carbonate?
hello , am trying to get a hold of some copper carbonate but its much too expensive.
now i have some raw, and untarnished (beyond normal anyways) copper laying around and want to know if theres any way i can convert this into pure copper carbonate, with minimal impurities such as copper oxides and such.
is there a way to do this through electrolysis perhaps?
also, is there a way to convert copper and copper oxide to copper hydroxide which i can simply add carbonic acid to to copper carbonate?
also whoever answers my question will get a best anser form me , guaranteed
You could mix an aqueous solution of copper(2) sulfate with an aqueous solution of sodium carbonate. Copper(2) carbonate is insoluble in water, and it should emerge as a precipitate. I got the idea from the Wikipedia page on copper(2) carbonate, here:
http://en.wikipedia.org/wiki/Copper%28II%29_carbonate
I know you said you have copper metal rather than soluble copper(2) sulfate, but I saw an Instructable in the related panel ---->
for making CuSO4.  Here:
https://www.instructables.com/id/Make-Copper-Sulfate-from-Copper-and-Sulfuric-acid-/
THE0DEN1 year ago
I made copper carbonate by accident the other day as I was preforming electrolysis. In a water-filled container ( not unlike a Hoffman apparatus ), I had copper wire wrapped around two carbon rods which I used for electrodes. After sending electric current through the water for some time, the copper wire started to rust and the carbon rods began to flake. Soon enough, I had a millimeter thick layer of bright blue copper carbonate sitting at the bottom of a container.
To make copper carbonate (CuCO3), you can use the formula CuO3 + C = CuCO3. Try soaking some charcoal and copper rust in water.
What do you need copper carbonate for?
That exact same thing happened with me. I was trying to make hydrogen from electrolysis what ended up making copper carbonate instead.
NachoMahma6 years ago
. Google your title. Ask specific questions if you run into problems.
oldmanbeefjerky (author)  NachoMahma6 years ago
ive been trying that for days, cant you please tell me?
