how can i make (yes make) a flyback transformer at home?
using garbage and no stuff like 805868 transistors or whatever you call that. it shiould be not form a tv crt
goeon8 years ago
how did a guest write this
cactus28 years ago
Transistors are absolutely unneccessary from any form of transformer.
http://en.wikipedia.org/wiki/Flyback_transformer
"Around a ferrite rod the primary is wound first and around this the secondary. This is to reduce the leakage inductance of the primary. And around this a ferrite frame closing the magnetic field lines. The gap between the rod and the frame is an air gap which reduces the remanence. The secondary is wound layer by layer with enameled wire with mylar film between the layers. In this way parts of the wire with higher voltage between them have more dielectric material between them."
