how complex of a build would a digital audio recorder be, and does anyone know of a circuit?
preferably small and SD compatible?
orksecurity7 years ago
Preamp.
Analog-to-Digital converter capable of running at a decent data rate.
Processor fast enough to pull the data off that converter at a decent data rate and write it to flash memory. Ideally , fast enough to do data compression.
Software to handle that, including managing the memory-based filesystem.
Sufficient, fast enough, memory for program and for audio storage and for working space.
Interface circuitry, power supply, mechanicals for mounting and control.
If you already know how to design/build/program all of that, it's not complex. If you don't, it is. Not a beginner project, I think, nor even a beginner microcontroller project.  And doing it yourself will almost certainly cost you several times what buying one off the shelf would.
Re-design7 years ago
Pretty significant to design and build from scratch.  I don't know of a circuit but have never looked.
You could start out with an mp3 player that has a record function and add some controls to that.
revelae (author)  Re-design7 years ago
only really would have to record, i could download it directly off the flash
