i have a problem with the sound on my computer. it does work, only...I can only hear the music.
in games, videos, music, etc. I can hear the background 'instrumental' music, but the voices are really quiet. I can't really hear what's said.
what can the solution be?
You may want to check the speakers you're using. I've had headphone that got damaged, and then they acted just the way you describe. Voice was quiet or missing, music was fine.
Another possibility could be an equalizer. If you have one on your machine you'll likely find it in the same place as the volume control seandogue mentioned. You may be able to adjust the sliders to fix your issue.
the speakers are (as far as i know) undamaged, however, my computer does not recognize the speakers as 'speakers' anymore, but as 'stereo-line in'. and i still have the problem with headphones. i did check the equalizer, but it does not help.
Like sean is saying: down the bottom right (Windows assumed) by the clock should be a grey speaker (says "Volume" on a mouse-hover. Open that up. You might need to use Options>Properties to show all the channels. I think he's probably right on the explanation.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
L
