how do i connect this motor?
it works on 230V (european standard voltage)
i've tested it with the original PCB attached, and it works (pretty fast :D )
but it has 4 more wires than im used to for an electronic motor.
also, there where 2 coil kind of components attached to what i recognize as the normal terminals (those with the drag contacts)
my idea, is that the 4 extra wires are for 2 electromagnets, instead of normal magnets, that im used to.
but then, i need to know how to connect the 4 extra wires.
note, im just interested in making it spin...
edit:
added PCB images
12
answers
Answer it!
A/C motors can tend to just vibrate back and forth rapidly instead of picking up, unless their special spin-up electronics are working.
The circuit board that goes with it probably controls everything together, so that phase timing is handled right there at the back of the motor.
Color codes? Printed data (from side of motor?) Clearer image? PCB photo? Source of the motor and PCB?
Hmm...on the other hand, it could just be a 3-phase motor
but that shouldnt matter right?
oftopic;
lemonie, seriously, every time i ask something, look at other questions, i see you!
how come? are u this savant-like person with half the internet in your memory?
and how long do you spend on instructables.com to manage that?!
The answer will be in the PCB, can you figure out what that does or post a picture.
I spend some time each day here, but so do most other people on this page.
L
