how do i fix my ibm thinkpad 600x , when i turn it on it gives error 8611 ?
sometimes gives
161
163
173
301
Etc etc, ive seen wud these codes mean, read a lot of instructions, but seriously, i need a REAL solution!
So, if you've seen what these messages mean, what have you done to fix them ? Like reseating the keyboard cable, changing the back-up battery etc ? Have you tried to fix them ?
Steve
N.Khan (author)  steveastrouk6 years ago
dude, ive reset the keyboard, (my mouse got flushed in the toilet) bt nowhere it sais that its a mouse problem, nyways, ive reset the keyboar, hit the motherboard wid a hammer (didnt brk it, still turns on and gives stupid error numbers) ive heated the thing wid a lighter, put it in the freezer, (in one sentence ive tryed evrything i found on net so far, and tryd some stuff my self)
All these tests and nothing,,
Wud da hell should i do, i want it fixed i really luvv it, bt nothing doin anything :/
You haven' changed the back-up battery ?
i really need to go to a lot of trouble to do dat, (ibm service center is pretty far) ,, but i didnt try bcoz the battery error only comes a few times, mostly its ok
I think hitting it with a hammer and attacking it with a lighter will have killed any chances of making it work properly now.
owwh come on!!!, it still gives the same damn error msg 8611 , and i only tried to burn off the plastic around a broken screw and when failed later on broke it with a hammer, ,,,
What do u have to say about this so called 8611 ??
See my link for a suggested fix for the 8611 code, but from the errors you're getting and the treatment you've given it since, I think you should stop wasting your time on this and get hold of something a bit more functional.
And a word of advice - laptops will work for a lot longer if you treat them with some degree of care.
Vyger N.Khan6 years ago
So its terminal then. Sometimes things are beyond fixing, you will learn that better as you log in a few years.
76543216 years ago
Why on earth would you use a lighter and a hammer on your motherboard?
N.Khan (author)  76543216 years ago
7654321 N.Khan6 years ago
according to my google search, the 8611 error is a "trackpoint error, most likely in your keyboard or subcard"
Vyger6 years ago
Its a pretty old notebook, Pentium 2 running windows 98 from I can tell.
It might be time to upgrade. Anyway if you try Google you can find a lot. Here is one link from a support forum.
http://www.fixya.com/support/t290907-ibm_thinkpad_600x_pc_notebook_08611
And then you can go to Lenovo's list of error codes. Which is here
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=lwik-3sr4pw
From what I am reading I thinks its dying, and aspirin will not help it.
N.Khan (author)  Vyger6 years ago
ive seen all of these, nothing has helped so far
AndyGadget6 years ago
The third post HERE suggests it's a trackpoint detection problem, and suggests a fix for it.
Several years ago I had a 600x where it stalled at bootup because the processor fan wasn't running.  My fix was to blow hard into the side port to spin the fan each time I booted it and that kicked it into life.
N.Khan (author)  AndyGadget6 years ago
huh?
But the fan does spinn, mayb nt really fast, i do recken the processor getting really hot, bt the fan's not on the processor its on the motherboard, no wonder which stupid idiot put a fan on capasitors, bt were u havin the same error msg....?
