Usb ports are obviously soldered to the mobo,anything that is loose will eventually fail as both ports on my laptop did.A bit of a sticky wicket for you if that happens right?.There really isnt a way to shore up the loose port so the more often its used......well. When the port fails pay someone to replace it or do it yourself.I did my own USB replacement at very little cost,if you want to know more about how its done just drop me a line.
Some USB thumb drives fit better then others. The ones that are just the PCB sticking out and don't have the metal can around it don't fit snugly. There isn't anything you can do to fix that. If your thumb drive does have the metal can then you can see the prongs on the plug in the laptop that put pressure on the can and fit in the little square cut outs. You can carefully bend those prongs inward a bit to hold the drive better.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
good luck
Tragic
