3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how do i make my guitar sound?
how do i make my guitar sound like other punk/ hard rock bands. i heard i need a desotrtion pedal. tell me what to do with one ime new to guitar what is a destortion pedal any way also my guitar is a fender starcaster if that helps. what i mean is i play the notes right but it isnt sounding the same so help if you know what i mean.             guitars are frusterating little things arnet they.
Nov 3, 2009. 8:14 AMseandogue says:
A distortion box is simply a purposefully poorly constructed amplifier that literally distorts the waveform that is inputted to it.
The result is a "gravelly" or grinding sound.  The power amplifier and its preamplification stages also influences the output by injecting its own distortion.
To mimic the sound that a particular guitarist has, you may need to duplicate his/her equipment to achieve the end, because each piece of equipment injects its own component to the final sound, including both the amplifier/effects and the specific guitar.
More over, guitarists often use multiple effects, so what you're hearing may not simple be distortion, but it may combine compression, expansion, chorus, and other effects to achieve the sound.
You do not have to be good to use one. In fact, many really lousy musicians use them to mask their ineptitude. In fact, it is in my 37 years of guitar playing experience the first effect pedal that most guitarists purchase.
Nov 4, 2009. 7:10 AMseandogue says:
(removed by author or community request)
Nov 4, 2009. 10:40 PMseandogue says:
Nov 22, 2009. 12:40 PMgtrgy says:
not exactly, each effect pedal has an input and an output, you simply connect the pedals using small cords. You have to play around with the order in which you connect the pedals to get the sound you want too.
Nov 2, 2009. 6:24 PMacidbass says:
google guitar pedals and look at punk slash hard rock pedals but to play with one you have to be good
Nov 2, 2009. 6:19 PMRe-design says:
Unless you can really play pretty good then you're just wasting your money.
But if you can the search "guitar effects".  You will find lots of sites that help you build your own effects.  Even if you don't want to build your own what you are looking for is the mp3 sample pages.  Thats where they have mp3's of what the effect sounds like.  That will let you pick what sound you are looking for.
Sometimes it's not the effect but it's the amp.  I hate to admit it but they really do sound different.  And the guitars sound different also so it's not just the effect you're looking for but a conglomeration of all of it.
Research the sound you are looking to play.  Then work on your technique.
Good luck.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
