how do you get plastic cups apart that are stuck together?
Burf7 years ago
Run hot water over the bottom cup until it is as hot as it will get, then pour cold water into the top cup and pull them apart immediately. The heat expansion of the bottom cup and the contraction of the top cup should be enough to break the seal so you can pull them apart.
seandogue Burf7 years ago
+2
NachoMahma Burf7 years ago
.  That's what I would try first.
.  Use a little percussive force, if needed. Ie, give it a good rap on the counter.
Re-design7 years ago
Slightly deform (squeeze) the inside cup and pull/twist at the same time.
Acepilot427 years ago
you gotta keep 'em seperated.
ummm...can you give some more description, how are the stuck together, maybe a picture?
AI
