loading
how do you make a ball machine path switcher?
Shadowman397 years ago
These are the best kind to make; the ones used in Big Ball Factory.<br /><a href="https://www.instructables.com/id/SF38KMUF9AZJLUK/">www.instructables.com/id/SF38KMUF9AZJLUK/</a><br /><br />The second picture is the one you'll want to look at.<br />
lioneatr7 years ago
Ok, i am going to use an example to help you: <a href="https://www.instructables.com/id/SUME7ZIF9N26PIV/">https://www.instructables.com/id/SUME7ZIF9N26PIV/</a> So basically you put four rods on two yellow connectors in the last connection point and then connect them by putting rods across the connection points next to them. You now can put white rods in the middle connector . Now slide your figure onto a rod and connect to your ball machine!
