how do you make a pulley washline like the amish use?
i know that the pulley closest to the house is larger,possibly a small bycycle wheel. the rope goes around it and out to another wheel or pulley     how do i make one so my wash will go out and back by pulling on the line?
Re-design6 years ago
Hang a pulley on each wall.
String a line thru both of them and tie the ends together.
Now pull on the bottom line and the top line will move out or vice-versa.
They can be the same size, there is no benefit to having one larger than the other.
They should be strong enough to handle the weight of the wet cloths.
+1
Use a turnbuckle to stop the lines from sagging - and use a strong enough line, aUV stable covered steel rope is fine.
Here's the type pulley you need.
I've seen them for as little as $5.
