3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how do you make a voltage splitter to dividea current in two so they act as if they were coming from different sources
hello, i am building and rc tank that uses 4 relays to power 2 motors in both forwards motion and backwards, all running from 1 battery pack. however ive hit a snag in my developements in which the single battery pack was actually bypassing the relays as it connected to the terminals of the motors, therefore not allowing me to use one relay to apply +/- power the motor via the battery and useing another to apply -/+ via another. my only logical solution at the time was to remove 1 of the 3 battery packs being used (were each batpack contains 10X1.2v 3AH AA batteries), and arrange it so that 1 pack powerd the motor when going in reverse, and the other two were to power the motor going forwards, and although this means that my tank would run fine, and the subtraction of 1 pack doesnt make a difference power wise to the motors as they run at max efficiency with 2 packs, its still a real hassle to recharge them as i cant just charge em all up at once, the reverse motor battery pack may run out before the forwards, and vice versa, giving me less time to run the tank, than if they were together.
so now you know my problem, what i need is a solution, how can i make a voltage splitter or current splitter or whatever, so that it can divide a current in two so that if i were to connect a positive wire from current 1, and negative wire from current 2 it would not complete a circuit, and basically act like they come from two totally different sources. this was what i was doing until i realised that when i tested the motors in either direction, it was actually going forwards each time i switched it on, after swaping the wires around when it would just run the motor if the relays werent even turned on. my tank has nothing yet on its motors shafts like gears or nothing, it was a simple mistake.
so please, can anyone help me?
Nov 18, 2010. 5:29 AMorksecurity says:
It sounds to me as if your problem was that you were trying to reverse the motor using a single-pole relay connection, whereas you actually need a two-pole connection (DPDT)... you need to exchange the two wires running to the motor, not just move one of them.
Nov 18, 2010. 9:17 PMorksecurity says:
Double-pole, double-throw relay.
When coil is off, input A is connected to output A0 and input B is connected to output B0.
When coil is on, input A is connected to output A1 and input B is connected to output B1.
Then all you need to do is connect A and B to power, A0 to B1 and one side of your motor, and A1 to B0 and the other side of your motor. With relay on, motor runs one direction; with relay off, it runs the other direction.
Nov 18, 2010. 9:19 PMorksecurity says:
Note that this doesn't require two separate power sources.
DPDT relays are commonly available and cheap.
Nov 18, 2010. 1:24 PMlemonie says:
Your wiring is wrong. Can you give us your circuit-diagram?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
