make an instructable and then click publish select knex and one other catagory or not then type in two keywords like knex and whatever it and slide the bar for cost( higher for alot of pieces lower for not that much) slide the difficulty bar for how hard it is to build and enter it in any contests by checking the box next to the contest picture then choose the license attribution-noncommercial-sharealike if you want to allow other people to use your design aslong as they give you credit for it. read the others for more information about license's. and thats how you post an knex ible, it takes a while for your ible to appear(up to 48 hours) and sometimes it can be rejected for copyrighted material.
You would post it just like any other instructable. If you are thinking of starting one, go on Your page (press "you" on the top right corner), then click "Instructables", and then on "Unpublished." You should see an orange box saying: "Click to start an instructable."
Some specific advice though; make sure the pieces are in focus, and write instructions that are slightly more detailed than "make the thing in the photo".
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
A) the piece is not already made on instructables
B) is worth postinh (with all due respect a gun from 15 knexpieces is not considerd good)
Although you should probably check these two before you start writing ;)
