how do you set up a computer surround sound system?
Hi, I recently asked a question about setting up a home audio system for the TV, but it turns out that the system I have is meant for the computer, so I am wondering how to set them up for the computer.  Do i need this?
http://www.google.com/products/catalog?q=computer+surround+sound+card&um=1&ie=UTF-8&tbm=shop&cid=13346619482042638583&sa=X&ei=3XKDTv7QFemPsQLJ8PnxBw&ved=0CFIQ8wIwBQ
or something similar?  If not, do I need a type of program?  I'm kinda on a budget, so the cheaper the better.  Thanks in advance! :D
Sep 28, 2011. 8:58 PMfrollard says:
You need 2 male to male 'headphone' 3.5mm stereo jacks to get surround, and the computer needs to support (most do) outputting 4 channels, it will have a green output and a black output which match the picture. In the computer, you need to adjust your sound card settings to a mode that allows 4 channel speakers.
Remember again, the red one marked 'right speaker' is an output also. It's bigger so that it can accommodate the volume control knob wires.
In a pinch, if you DON'T have a computer capable of 4 channel output, then you can just hook up the green cable (1 stereo cable) and the speakers should output just stereo through the 4 speakers (+ subwoofer).
ymmv.
Sep 29, 2011. 5:13 AMKaydenST says:
Frollard has all the right answers. Good luck! You should be able to buy a sound card for your computer if you are tech savvy.
Sep 29, 2011. 4:56 AMjoespicnictables says:
If you just want four speakers around you, you can splice it so there is 4 speaker connections.
Sep 28, 2011. 1:54 PMsteveastrouk says:
Most PCs these days have 5.1 as standard - check your motherboard spec. All you need then are some simple leads
Sep 28, 2011. 7:09 PMthegeeke says:
That isn't a 5.1 system that he has pictured there. It's a 4.0 or 4.1. (I can't tell which, but I would guess 4.0.)
Sep 28, 2011. 8:55 PMfrollard says:
That's the back of the sub, it doesn't have a sub channel, just amplified bass from the other channels.
Sep 29, 2011. 4:43 AMthegeeke says:
Correct. It has 4 channels, but it outputs a virtual 4.1. (And yes, I've seen a few surround sound systems in my day... I used to setup 1/4 million dollar home theaters for a living!) ;)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
