how many ohm resistor do i need to get 5v from a 9v battery?
hello i am writing up an instructable on setting up a wireless receiver , however i requires both 5v and 9v output, and the whole point of it is that it is simple and cheap, so i need to know, how many ohm resistor do i need to step down 9v down to 5v?
i do not wish to use a 5v regulator unless one can be bought for less than $2, or else the instructable will cost too much.
kelseymh6 years ago
V=IR. You need to know the current draw. If the current draw is variable, then what you ask is not possible without a proper regulator, such as the 7805.
oldmanbeefjerky (author)  kelseymh6 years ago
hmm, i have considerd that that regulator is cheap enough to use. may i ask, how is it wired up?
i cannot seem to find a simplified set of instructions for it!
the data sheet should show how to wire a 7805 - NOTE it needs some voltage overhead to do its work.
oldmanbeefjerky (author)  rickharris6 years ago
ah i get it now, the input and output negative can be either the ground middle pin or the bolt hole thing/heatsink (i dont know the name)
what do you mean? like it needs to have over 5v to work?
i think the current draw would be about 20ma, which means that
5V = 0.02 x ?
5 / 0.02 = 250!
thanks, ill have to try this out to see if it works before giving you a best answer
A standard 7805 needs a couple of volts of headroom to work, so 9 to 5 is fine. For reference, if you need to, there are low-dropout regulators, which can work with less than 300mV of headroom.
DON'T forget that there is no "magic" here and all the heat a resistor would dissipate will be dissipated by the regulator.
Steve
oldmanbeefjerky (author)  steveastrouk6 years ago
of course, though heat isnt really a problem here since it is only needed for temporary power, and at idle, only 3-5ma will be drawn so there wont really be that much strain on the regulator.
darn, why must you give such a good answer i cannot make "best answer"........
In that case you can use the tiny "LM78L05" instead of the chunky 7805.
Steve
i already bought 10x 7805's, though i will look into these smaller ones you mentioned as i will be selling them individually on my site for less than individual ones on ebay, still i must give kelseymh best answer
