how simply/ easy can a cnc project be?
how i was wondering if I could make a cheap CNC (possibly combined 3d printer) without making it a "big" project.
if I buy stepper motors and driver, and dowlad some software, all i need is the mechanicle parts right? (like the frame and stuff, like a spindle/ melted-plastic-extruder)? please come with some inputs ;)
Oct 10, 2012. 3:55 AMliquidhandwash says:
have a look at
https://www.inventables.com/
they have a kit, and cheap hardware to build a cnc mill
Oct 9, 2012. 12:32 PMbwrussell says:
Well extruders are several hundred dollers and they need their own controls. Honestly a CNC mill/router is simpler. There are several small cheap mills on the site. The problem is that the mechanical pieces aren't exactly cheap (slide rods, bushings, threaded rods, etc). If you're willing to lose some precision you can use cheaper materials and some o the guides here do that. Check the 'Related' bar to the right. ---->
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
