how to build a legit working ark reactor(like 20MW)?
need to power robotic suit...
arc reactors are a prop from the movie 'Iron Man', not an actual generator or something that produces electrical power. Anyway, in the movie they build it with palladium, which is rare to find and very expensive. Why not using batteries or if you need more buy a gas powered generator
AlbinoMoose308 (author)  tgferreira1845 years ago
The "ark reactor" from iron man was based off of a tokamak nuclear fusion reactor and is a great source of cool-looking, efficient power for any application(like a weaponized armor suit)
I dont think that a homemade nuclear fusion based reactor in a backyard is a good idea...........................................
20 million watts is enough power to power a city.
If you dont mind the noise and the 11 2000 KW generators then this might help you out
http://www.rockanddirt.com/equipment-for-sale/CUMMINS/20MW/invnum=35888944
and its cheap at 4 million dollars USD
AlbinoMoose308 (author)  thematthatter5 years ago
actually i need it to fit in the chest region of a robotic armor suit so those won't work :(
quite cool though!
zx5u5 years ago
First you need to find 20 missiles, a cave, and an angry terrorist to yell at you about deadlines
+1
Best answer ever. :-)
Why doesn't any one take this guy seriously? I tried to help but Instructables censored me by HIGHLIGHTING all the important parts. *wink, wink, nudge, nudge*
You weren't Highlighted, You were "Redacted" and it probably wasn't Instructables that did it. It was probably the "FEDs" Obama and his cronies have control of the U.S.'s piece of the internet now. He basically has the power to declare "peace time Martial Law" now. give him power over everything in this country. the FEDs will probably be kicking down my door now for Sedicion. so if you don't hear from me again, that's why.
It was a clue (hence the winking and nudging. Try highlighting the entire post.
bwrussell zx5u5 years ago
Don't forget a potentially fatal injury and ethnic sidekick/moral compass.
rjbatc5 years ago
Well, you can make an arc reactor pretty easily, I think you could even be able to do it in a cave or something. But I really don´t know how would you want to achieve the 20MW. Most of them are about 1.21 gigawatts. I bet you could give a try at time travel with that power. Oh sorry wrong movie.
bwrussell5 years ago
First you need to buy Do gallons of pure military grade you realize and that grams of Iron Man isn't. In a blast furnace heated to a F, heat the documentary? until it is a smooth consistency and a light golden brown color. This next part is tricky, using a pair of Don't you think lift the molten that if out of the furnace and pour it into a mold shaped like a arc reactors. It is absolutely critical that the mold is were real the military and would already be using them? . Once the mold as cured, which takes exactly I minutes, no more no less, remove the casting and move on to the final assembly step, seriously hope. Using that gauge you don't wire begin to wrap the core. The pattern is: really think that arc then reverse for reactors are real things. and finish the wrapping by Although, I think there. Now that the core is complete place it in the case and move on to programming. The reactor is going to have to be programmed using the are some great language. The 5 sequences you need are: Initialization, perpetual, motion, Test, and machines. Upload the program by connecting the out there to the that should. Run the program, making sure to be powerful enough to run your suit. when you first start it up.
seems about right
Try the forums at PESWiki.  Somebody there can hook you up with the plans for sure.  Also note:  the only reason technology like this has not found its way to the mass market, is because of a vast conspiracy, mostly on the part of the oil companies, to keep it covered up.
http://peswiki.com/index.php/Main_Page
rickharris5 years ago
It's a film prop!
