it might be possible you can get a BT rs232 transceiver for $7.20 at DX that will make the connection with it it may be possible I have also seen this circuit on ebay for even cheeper
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
you need 2 things;
an app on the phone willing to open the bluetooth stack's serial port (if available on your model)
and a bluetooth enabled circuit that listens for that serial connection once paired to control the light.
Basically...not for anywhere near 10 dollars. Then there's the programming part - possible but takes some learnin'
