loading
how to charge a battery pack? jumpstarter mp350, wont charge, need to know if there is a way to fix it.
orksecurity7 years ago
Most of the consumer chumpstarters (sic) aren't designed to be particularly servicable, from what I've seen. You'd probably have to bust some plastic welds/glue joints, then figure out how to close it up again...
I believe these contain fairly standard gel-cell batteries, so if the problem is that the battery has died you can probably find a replacement that will fit.
Of course the problem could also be your charger. If it's an external wall-wart, you may want to check that it's supplying the correct voltage, and see whether the jumpstarter is drawing current when you're trying to charge it.
