how to connect a led bulb with battery and a switch ?
tylervitale4 years ago
If we're to assume that you're using a normal SPST switch with a battery which can indeed provide enough current and voltage to power the bulb, then it can be hooked up in a normal series circuit or "loop".
Also, (just to make sure I've covered all ground) ask yourself a question: Would you plug this bulb into a wall? If so, then it will not work with batteries. (unless you happen to have an abnormally high voltage battery)
bwrussell4 years ago
What size battery? What color, specs does the LED have? What kind of switch?
Giving some details will get this question answered as it is a simple answer but impossible to answer without more info.
Jayefuu4 years ago
Which part of it are you struggling with? What have you tried?
Reading this would be a good start:
https://www.instructables.com/id/LEDs-for-Beginners/
