how to control speed of brush-less dc motor(maxon EC16)?
I WAN CONTROL SPEED OF BRUSH LESS DC MOTOR... PLZ TELL ME VARIOUS METHODS AND BEST SUITABLE FOR BRUSH LESS DC.
THANKING
SatishW (author) 2 years ago
thank you all for your precious answers .... really thanks
Really, you can't beat the Maxon units....
+1
-max-2 years ago
-max-2 years ago
You use these little black-box devices called ESCs in the RC hobby:
http://www.amazon.com/s/ref=nb_sb_noss_2?url=searc...
You input any wide range of voltage sometimes as low as 6V to maybe as high as 25V or even more (depending on the ESC used. Small ones for RC stuff is about that range, 2S-6S LiPo.)
Assuming it is a 3 phase brushless motor like the outrunner motors popularly used for drones, and airplanes and stuff, They work by controlling power with the 3 push-pull outputs with an intelligent microprocessor such that the current through each of the 3 phases of the motor causes the rotor to rotate in the right direction with consistent amount of force. This is the basic operation for every brushless DC motor and even some 3 phase induction motors with solid state motor controllers, although they rely a slightly different principle physicly.
iceng2 years ago
In the early days the first brushless series fractional horsepower motors replaced the brushes with cadmium sulfide controlled transistors and the brush commutator was a half shade tube spinning around a miniature light bulb to simulate the actual two carbon brushes.
Your motor is a three phase (equivalent 6 brush) and you are given three hall flux armature sensors to activate a triple H BRIDGE. The easiest speed control is by power, raise the voltage for more speed and lower voltage for less speed.
Sometimes you can Pulse-Width-Modulate (PWM) motor power to control both brush and brushless motors without loosing torque but watch out for excessive heat at low speed.
seandogue2 years ago
Aside from the (IMO) right answer, (which btw, is Steve's re: buy it from Maxon) if you mean to learn how to create your own driver, try this google search.
brushless motor control theory design circuitry
Exactly as shown above. You'll receive a bunch of hits that you can evaluate to see if they offer the necessary fundamentals for learning how and maybe to see if you're up to the task if so inclined.. They may or not also suggest why buying the a specific component from a mfg is sometimes the BEST SUITABLE answer (Efficiency, reliability, durability, raw cost and dev cost, etc.).
Buy the drive from Maxon. Absolutely the best suitable.
Really not that hard at all:http://tinyurl.com/p9mrdug
