loading
how to make 12v battery from 18650 li ion batteries?
Hi,
I have this led strip
http://www.supernight.cc/supernight-tm-5m-16-4ft-smd5050-rgb-double-row-600-leds-tube-waterproof-led-flexible-strip-light-12v-120led-m-strip.html
Working Voltage is 12VDC.
Working Current/meter: 0.8-1A
the strip is 5 meter.
18650 x4 = 14.4 v
18650 x3 =10.8 v
How can I make it work with 18650 li ion batteries?
And how many battery must I use and how can I do that?
I think that I need driver or booster to get a stabil 12v!
work-time I need 5 h
Picture of how to make 12v battery from 18650 li ion batteries?
Downunder35m8 months ago
Get a proper 12V deep cycle battery, everything else is a total waste IMHO.
Otherwise check Google and Wikipedia on how to combine batteries.
But for your lithium cells you will need either a step up, or a step down converter, best with additional battery undervoltage protection.
Cr77777 (author)  Downunder35m8 months ago
if we did it , can we get more capacity by group of cells and only 12 volts?
each 18650 = 3.6v
18650 x4 = 14.4 v
18650 x3 =10.8 v
I use samsung 3000map each, so if I use 4 cells I will have 4x3000 = 12000map, it will be expensive if i buy it and I love to make these things at home :).
Can I use more cells to get more capacity but only 12v?
which battery undervoltage protection can I use?
which step down can I use?
3.6 volts to 4.2 volts fully charged isn't going to give you 12 volts without some kind of regulator. Plenty of 12 volt regulators around.
Your laptop batteries may already have a protection cct attached to them, many 18650 cells do.
However Ebay or an electronics supplier can give you a suitable under and over voltage protection cct.
Cells in series will add the voltage, cells in parallel will increase capacity. So you need a series / parallel set up.
You will need to arrange for a suitable charger for such a set up though Li ion cells are sensitive to over charging - i.e. they may burst into flames.
