how to make a positive and negative wire out of one wire?
I am building a robot and I need to know how to connect the wires in the power cell to a switch, then to the motor. It is a DC motor. I am in robotics.
I don't understand the question. The obvious answer would seem to be "cut the wire in half so you have two wires", but one would hope you aren't asking anything so obvious.
You wire a motor exactly the same way you wire a light bulb. Does that help?
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
<muzzles self>You wire a motor exactly the same way you wire a light bulb. Does that help?
