how to make a rubber part that doesnt exist ?
hi good peoples, i work at a place that makes and sells beef jerky and smokies. quite recenty one of the machines we use to cut them from links quit working properly and needs a new rubber pad for the clutch that stops the blade. the problem is the company we bought the machines and all parts for them it died with the owner so we cant replace them. my question is how hard would it be to mold rubber into a new brake pad for the clutch. i will put up pictures of the clutch and pad as soon as i can but i might as well start with the first problem how to cast and mold a rubber sturdy enough to do the job. all info on this would be greatly appreciated
side note: now that i have the parts this is what they look like. two very soft rubber wheels with a concave treaded surface. the rubber tread is really worn down hence the need for replacement
nicelly5 years ago
If you’re all the brazen sort you’re able to sashay even the store's fragrance countertop inside the community department retailer. This can come to be frightening territory for some men (as well in the form of few females) because it is known everybody might could be seen as they know a thing are
polo ralph laurenunable to. Well, that they more than likely perform, nevertheless the software doesn’t matter. Just how issues is basically you ought to buy your scent.
rickharris5 years ago
With no picture it's hard to foretell the future!
Where are you?
Picture or at least some kind of spec.
BUT
You could try replacing the old pad by gluing on some rubber reclaimed from and old inner tube OR even an old bike or car tyre.
snowfox222 (author)  rickharris5 years ago
im from ohio, and when i wrote this i was unfortunately unprepared. i will hopefully have the part and pictures in my possesion
The chances are that the parts used are standard ones, very few people make ALL the components of a machine. We need to see pictures.
Steve
canucksgirl5 years ago
Pictures would really help. It's hard to simply imagine the part and therefore give you some suggestions on how to cast it, when perhaps there are better alternatives.
Interesting pictures of rubbery, and other, cast objects are appearing in the related panel.  On the right side of the screen, here: --------------->
