loading
how to make liquid antifreeze concrete?
i need that how make liquid antifreeze concrete & a new formulation for product,thanks my friends
iceng5 years ago
Up here in the mountains alcohol is added.
Also antifreezing concrete admixture low dosage: 2.0-4.0% suitable for
the winter construction JK-15 is naphthalene-based ...
Setting Concrete is moderately exothermic.
Cover the concrete for the first 24hrs when it must not freeze.
anoosh khan (author) 5 years ago
yes,its true,plz help me and give me an formulation about that,thank u
Mix aluminium powder in the mix creates bubbles.
nofunclub5 years ago
you might find some answers there
Freeze-Thaw Resistance
http://www.cement.org/tech/cct_dur_freeze-thaw.asp
or there
Process for preparing frost resistant concrete
http://www.freepatentsonline.com/4057526.html
both from the first googlesearch page
https://www.google.com/search?q=frost+resistant+concrete
FoolishSage5 years ago
You can buy air-entraining portland cement and use it regularly. If you already have a regular portland cement you can add air-entraining additives between 5% and 8% by volume.
Either type of cement has small air pockets which will make it resistant to freeze/thaw cycles.
rickharris5 years ago
Do you mean frost resistant concrete?
