how to make paper hydrophobic and waterproof?
I want to make a vase of paper, by the principle of the paper beads. My question is: how can i made the vase hydrophobic and waterproof?
rickharris6 years ago
You can buy waxed paper you know in most cook shops.
76543216 years ago
Read here
* 1
You will need 6 ounces of alum, 1 ounce of grated castile soap, 1 quart of water and 3 ¾ ounces of beeswax. Alum can be found in a grocery store spice aisle. Beeswax can be found online and at health food stores.
* 2
Place 1 quart of water in a pot on the stove over a medium heat. Add 6 ounces of alum and 1 ounce of castile soap.
* 3
Bring the mixture to a boil. Stir continuously to dissolve the alum and castile soap.
* 4
Add 3 ¾ ounces of beeswax and melt it into the boiling water. Continue to stir continuously.
* 5
Once the beeswax has melted in, remove the pot from the heat.
* 6
Pour the solution into a pan or container large enough to fit the paper you want to make waterproof.
* 7
One sheet at a time, place the paper into the solution. Use tongs because this mixture will be hot. Handle carefully.
* 8
Remove the paper immediately after it has been submerged, do not leave it in the solution to soak. Place it on wax paper to dry.
Steep it in molten wax ?
Spray thoroughly with a polyurethane varnish ?
Steve
+Steep it in molten wax
L
I like the varnish idea best.
"hydrophobic: a dreaded fear of any bodie of water"
i cant imagin why you would want to make paper afraid of water, but if you want to make a vase out of paper, or anything really out of paper, wateproof, get yourself some polystyrene, and by weight, add 1 10th part polystyrene to either acetone, gasoline or methylated spirits.
this will make an extremely weak laquor, which will easily soak into paper, and harden to have a final strength equal to that of a plastic milk bottle!, and will be very waterproof, i use this to waterproof my smoke bombs and fuses so i can let them off underwater, and i tell you, it works.
the addition of a dense oily substance like wax, will make it more pleasant to touch, and will feel like normal smooth plastic even more. wax will dissolve in gasoline, but only a little bit, say maybe 1 5th of how much polystyrene you added, or else it will feel waxy
http://en.wikipedia.org/wiki/Hydrophobic
contrast with
http://en.wikipedia.org/wiki/Hydrophilic
seandogue6 years ago
traditionally, I think you oil it. Not sure how you keep ink from running though or what oil you would use.
+1
