how to make simulated water resin?
Have been using a prod called "Quickwater" to set up branches in small metal dishes.  This product is unavailable & rather expensive.  I think I will eventually need about 2 to 5 gallons for my project.
canucksgirl5 years ago
The Quick Water product is also known as "acrylic water". In any case it is rather expensive, primarily due to its 'exceptional transparency'. There are a variety of other products available and searching based on a "casting resin" will yield you the best results.
For example there is a Florida based company HERE that sells Polyester Casting Resin. For 5 gallons, the cost is $144 U.S.
Unless you plan to become an Organic Chemist, purchasing a product will likely be your only option.
rickharris5 years ago
I am guessing you can't make it as such. It is most likely a polyester resin.
Clear casting resin may do the job bust isn't cheap either.
Try to find a bulk supplier as the more you buy the cheaper it will be.
You don't say where in the world you are.
