how to put a jeep cherokee window regulator back in the door?
i got the part out and put the new part together but i cant figure out how where to screw part of it in. In the picture it is the lower left part.
Picture of how to put a jeep cherokee window regulator back in the door?
acidbass7 years ago
mmmmmm did it come with instructions did you get the part for the right year i would see if there are these probs first then if there arent it should go exactly where the old one was (if you took the old one out) even if you did not you still should have the original screw hole in the door
NachoMahma7 years ago
.  As shown, the angle of the bracket (measured from the horizontal) should be pretty close (it could also be near to parallel to the arm it is attached to). Unless the regulator is in the full down position, it needs to move a little to the left and up. That should get you close enough that you can see which holes in the door are used.
.  Double-check that you have the right part.
.  Take pictures before taking stuff apart. ;)
