loading
how to reimage dell wyse wt3125se?
hi i have using dell wyse wt325se thin clients in my office  two of them shows flash memory error i tried to reimage it using netxfer but it wont work please guide me...
Not impossible that the flash memory has failed - only option is to change the chips, and hope you can reprogram them
dhananjaiswetha (author)  steveastrouk3 years ago
how to reprogram the flash memory
Do you have a the flash image ?
no but i have firmware .rsp file
You need to take the file apart and see how .rsp files are made, and then you'll probably have to turn it into a .hex file for an EPROM programmer with the right drivers for your FLASH chips.
can you help me on this by instruct me to do by step by step process...
No, sorry, I don't have the time.
its ok thanks for your advice
If the drive fails it's a bit late to image the drive. Even if you did you would have a currupted image that wouldn't work.
dhananjaiswetha (author)  mpilchfamily3 years ago
i have similar working wt3125se could take image from that
He must have the image that he was trying to flash
I dunno. There might be a way to reimage it over a parallel port cable. I remember doing this for a wt3360se with a tool called "xfer" which had to be run on a machine running MS-DOS. If I remember the version of this tool I found was bundled with a working version of MS-DOS into a iso for a bootable CD, so that one could just burn that iso to a CD. Then use that CD in an old computer, booting from the CD, to get set up to use this "xfer" tool.
Searching, just now, I found "xfer" here:
http://www.freewysemonkeys.com/modules.php?name=Do...
But I don't recall the place where I found xfer and MS-DOS bundled into a bootable CD-image.
Also this site,
http://winterm.gaast.net/main.php/news.html
might have mentioned something about the reimage-over-parallel-cable trick, because I was trying to reimage my wt3360se with a version of Linux instead of WinCE, or whatever it is those things usually run.
