3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to repair cigarette burns in carpet?
I burnt my carpet and need instruction as to how to repair it.
Nov 13, 2010. 7:08 PMorksecurity says:
I don't know of any _good_ way to do so, outside of finding a piece of matching carpet and somehow splicing that in to replace the damaged area.
Good argument for not smoking.
Nov 13, 2010. 11:33 PMLegoBrickMaster7 says:
Did you try searching? There's an Instructable on it with literally the exact wording of your question as the title.
Repair Cigarette Burns in Carpet
Good luck.
Nov 14, 2010. 8:31 AMaeray says:
Yep, this looks just like what I was advocating.
Nov 13, 2010. 8:13 PMaeray says:
Frollards answer is a good one. For a more extensive (and labor intensive) repair this works well: pull a corner or edge of the carpet out from under the baseboard trim, or better yet, out from under a baseboard heater and trim off a small pile of fibers, or clumps of fibers, or loops, depending on the type of carpet. Replace the carpet edge. Use hot glue to secure the donated material to the damaged area. It will take a bit of fiddling and skill, but the finished repair will be nearly invisible, but not particularly durable. Good luck.
Nov 13, 2010. 8:49 PMfrollard says:
carpet club for men? :D that's awesome!
Nov 13, 2010. 9:12 PMaeray says:
Yeah, yours is more of a "comb over" effect :)
Nov 14, 2010. 3:51 AMfrollard says:
Depends on the type of carpet -- I suppose you could do the glue-down thing by gluing individual lengths of yarn 'middle down' for open pile carpet to create a new forest in the area shaved down...scary though, especially in high traffic areas, as getting the colour right would be crucial.
Nov 14, 2010. 8:30 AMaeray says:
Yes, my method isn't very durable, but the color should be very close.
Nov 14, 2010. 12:28 AMrickharris says:
WARNING YOU TRY THIS AT YOUR OWN RISK
TRy cutting round the burn in a regular shape - A square for example. Cut a matching square from a clean hidden area e.g. under the furniture - use a carpet glue (Copydex is a good one) to glue the patch in place. Eventually the pile will amalgamate to disguise the patch.
A good carpet fitter will do this for you for a price.
when cutting the patch put a spare bit of carpet under the burn and cut through them both in this way they will both be the same shape.
Nov 13, 2010. 8:00 PMfrollard says:
At a friends house with limited success we used a few techniques:
Depending on the TYPE of carpet (whether the pile is open ended or looped) - open pile you can carefully snip the ends of the burnt fibers. If they are melted together it may take a more drastic 'haircut' to remove the damaged fiber tips. Feathering the cut edge is important so it doesn't look like quite so big a divot.
If you are really brave, you can get a 'sharp' dremel tool (as opposed to a dull grinder type attachment) and do a little haircut that way, again, be careful not to do MORE melting than there already is, hence the bladed tool.
Last case if these repairs fail is to replace a small patch, or the entire carpet. Kiss your security deposit goodbye.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
