loading
how to turn on a pc fan using an xbox 360 remote?
hi there and thanks for looking.
i am trying to work out how to turn on a pc fan that will vent the cupboard that my xbox 360 is in. if poss i would like it to be cheap as poss and be a not be connected to the xbox if using the remote is not poss then how could it be done when the xbox is running
I do believe I have exactly what you are looking for, this Instructable has two circuits that will turn on a fan, and they will work with any remote. In step 6 the circuit turns on the fan and keeps the fan on until you turn off the fan with the remote.
https://www.instructables.com/id/Ghost-Busted/
kturner6 (author) 3 years ago
thankyou for the quick replys am i reading the Josehf Murchison post right that fan only runs for a few secs then turns off or dose it stay on
iceng3 years ago
Simply use a Klixon thermal switch to control a quiet squirrel_cage fan right off the mains !
Be sure to select the temperature of the Klixon to activate the fan carefully.
Klixons are used to control in wall gas heater fans.
A
Use a thermostat in the box.
