hydrogen peroxide plus aluminium equals ... what?
I know that hydrogen peroxide and alcohol equals well"whoomph", but what happens if I mix hydrogen peroxide and aluminium?
orksecurity7 years ago
Almost certainly nothing. Aluminum oxide forms very quickly on contact with oxygen -- but  unlike iron oxide, it remains attached to the aluminum and forms a barrier layer that stops the reaction. (Which is why aluminum is so corrosion-resistant.)
I don't think hydrogen peroxide can cut through that. Feel free to try it, though.
Nothing.  I doubt the Aluminum would even do much to increase the decomp. rate of the H2O2 more than a little.
lemonie7 years ago
Probably nothing much. Why don't you try it?
The most I'd expect is that the peroxide would decompose.
L
flamesami (author)  lemonie7 years ago
hmm... then do you know of anything I can use with H2O2 to make an explosive?
Peroxide has a tendency to decompose, for explosives you need it upwards of 30% - have you got that? If you have I can do some Googing, or you could. There's nothing here that I know of.
L
I can distill it
you can google it
it's nearly 12p.m on this side of the atlantic
You would need to vacuum-distill it, and be very careful. I don't think this is a good idea as apart from being dangerous it's probably illegal.
L
I've seen it before, notice how it says "I am pretty sure the top one will be the Hydrogen Peroxide" - meaning it wasn't actually done it's just theory.
L
nepheron7 years ago
water+ gallium+aluminum -----> Hydrogen+ oxygen
