loading
i have a lead acid battery of 4.5 Amp 6v. i want to make a 6 leds torch so what to do.
i have a battery of 4.5 Amp/h 6v. i want to make a 6 leds torch so what to do. i connect the led's with this battery so those led's are damaged.please tell me what to do or show me software about this? any thing about the calculation or attaching resister of what value
rickharris6 years ago
http://led.linear1.org/led.wiz
This address should be made sticky - Not that that would ensure people read it.
ARJOON6 years ago
wikipedia says all. you did not put the resistors needed.
make sure that each resistor is in series to each led. and add them in parallel. the typical value of the resistor for each led will have to be 8-10k. they use a very very low power. so you can run it for weeks until the batteries is down. i have the same battery and i did the same error when i was new to electronics. so what i say is that we learn and progress from errors to perfection. correct me if i am wrong Steave.
The resistor is typically 150 Ohms, but otherwise you're fine.
oh yeah wrong calculation
What LED ? Specifically, what forward volt drop at what forward current ?
