i want my head phones to play louder is there a cheap easy way to do this?(ps volume is maxed already)
using this for my laptop so usb power is possible portable is best
CameronSS8 years ago
If you want headphones to play louder, you will have to connect them to some sort of amplifier. If you want to go cheap-and-dirty, rip open a set of powered speakers and connect your headphones to the speaker lines. If you want a more refined system, there are many Instructables about building amplifiers.
A bit of warning: if you have headphones amplified too much, besides risking hearing damage, you also may blow out the headphone speakers-they're not intended to be incredibly loud.
some speakers have headphones socket. this socket is powered from the amp too
But usually not as deafeningly loud as the main speaker. :P
i learned the loud way that only usually and not allways
paulie14wyh (author)  CameronSS8 years ago
thanks
this is a cheap and easy to build audio amp you could plug in in between your headphones and laptop. USB power is probably a good possibility as this is a low power circuit or you could use a 9V battery. http://www.generalguitargadgets.com/richardo/practiceamp/index.html
